trans question!!
Old 09-04-2007, 07:50 PM
vtechworld's Avatar
a b18gsr with hydro tranny.............will a cable b series trans bolt right up. my buddy is lookin into buying a gsr for his 92 ls.........his trans just blew up by the shift linkage.....so he wants to spend the money for a whole gsr.........so could he just swap over the cable linkage stuff to the hydro one? thanks
Old 09-05-2007, 01:28 AM
nosaj81_2004's Avatar
Member
a 94 b18gsr will bolt up to a cable trans. i my self have been pondering about doing a motor sway for my 91.
Old 09-11-2007, 10:24 PM
3gentegRa's Avatar
u will need the hydralic resivior along with mounting it its almost like the brakes
Old 09-12-2007, 07:55 PM
vtechworld's Avatar
my buddy wants to keep it cable, so he dont need that hydro stuff. should be able to just put the cable sh*t on the trans and take off the slave and stuff on it right?
Old 09-14-2007, 06:23 AM
hmmmm
pedal assemblys are a bit different as well as firewall reinforcements to hold that cable housing
also need to check your front motor mount i rember seeing a request for juice or cable tranz when ordering mounts.
there is also a spline change on the clutch disk from 20 -21 in 1991/1992
but if hes got the whole swap that wont matter.
wish i had a yes/no answer for you.
please keep us posted with what you find out.
Toyo_drifting
04-25-2008 12:33 AM
JD TL-S
08-28-2007 07:20 AM
Rigger
07-15-2006 09:22 AM
BigReese
04-18-2006 06:32 PM
01-31-2005 02:46 AM
Quick Reply: trans question!!
