trannys
Old Oct 16, 2008 | 10:25 PM
hottnikkels1974's Avatar
ive just started with this tuner stuff. my question is, is it possible to bolt an
automatic acura integra LS tranny to a gsr engine. please respond
Old Jan 11, 2009 | 10:23 PM
Teg4life's Avatar
yeah its possible but i wouldnt do it the peformance of the gsr engine will be lost due to trans gearing if i were you i would get ahold of a transmission off a b18 if your capable of driving a stick shift
Old Jan 11, 2009 | 10:41 PM
thanks, thats my problem, im in a wheelchair so 5 speed is out of the
question but if you have any suggestions let me know i will appreciate them.
thanks again.
Old Jan 11, 2009 | 10:44 PM
Teg4life's Avatar
oh i got you well what are you looking for you want it as a daily driver or are you wanting it to be really fast
Old Jan 11, 2009 | 10:50 PM
i have a 4 door LS, i dont want to go really fast but i do want to get up go
when necessary because it will be a daily driver but im tryna get as close to
200hp as i can with bolt on parts if its possible
Old Jan 12, 2009 | 11:24 AM
yes on the transmission but it is weak and not recommended in a gsr.
AND
the grs engine develops its power at5000-8500rpm that auto transmission will shift at 5500.if you hold it back in gear till you hit red line then allow the transmission to shift, IT WILL BREAK.
IF a auto is going to be installed behind a gsr. then spend the bucks and have it build to handle the power.
maybe look into a 2000+ accord or cl v6 and auto swap into a tegra. thats 240+hp and massive dependability fit will be tight.
Old Jan 12, 2009 | 12:56 PM
cool that sounds like a plan, thanks
alpineaudiokid
Jul 24, 2006 05:40 PM
