switching trannys
Hi. So i have a 91 tegi with a b20z and a jdm s1 tranny. as you know the S1 is really short geared so at 70 in 5th im at like 4500. I was wondering if i switch to an LS tranny how much "pep" would i lose and if my top speed right now is 110 what would it approximatly jump to??? oh and i have a type R flywheel.
Thanks.
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
ok, some of the best honda trannys are as follows,
YS1-cable tranny from 1st gen GSR
S80-hyraulic tranny from type r integra
S21-hydraulic tranny from 99-00 Civic Si
all of these trannys have great gear ratios and will bolt up to your motor. hydraulic trannys will require some work since your current setup should be a cable tranny.
as for speed and pep variations, all of these should help you to get up to more like 130-145 mph.
