no lights?
Old Feb 8, 2009 | 04:36 PM
xixi's Avatar
ok heres my problem. when i turn on my healdlights my instrument panel
lights or tailights dont go on. i checked fuses. i was thinking a loose
ground because they cam on briefly once when i hit a bump. so where
would this ground be? it's integra '96 base
Old Feb 8, 2009 | 09:30 PM
it maybe a ground or 2.
but i replace 1-2 headlight switches a month because of this problem.
tail lights ground in the rear of the vehicle. the dash grounds by your ankle.
Old Feb 18, 2009 | 01:01 PM
ndehelian's Avatar
Honda made vehicles are known for this in MHO..
I have 2 in our family and both do this.. note if you hit the hood with your fistright over the defective light it willpop back on.. and then when you go over a bump it will go back off..
I fixed this problem by replacing the bulb and placing a little salve, petroleum jelly, vasoline;what ever you want to call it, on the end of thelight bulb,it helps keep moisture off the contact and seems to help the conduction from being interupted.
Acuralegend is probably right about the switces due to the dash but my headlights due this on our two vehilces and the petro jell helps that issue
Hope this helps..Edited by: ndehelian
miked8887
Sep 17, 2008 10:17 PM
Acura Ray
May 28, 2008 08:52 PM
narus
Jun 11, 2007 10:02 PM
BrentK
Dec 31, 2006 12:42 AM
he3rbz
Nov 22, 2005 05:57 PM
