GSR engine in RS
Old May 6, 2008 | 05:50 PM
Paul L's Avatar
Hi All,
First post here and I need opinion. I have a 1996 Integra with quite a lot of aftermarket upgrade (such as lower suspension, CAI etc),our local Acura diagnosis that one of the cylinder is weak and need repair soon. Rather the repair the cylinder, I am thinking of replacing it by a GS-R engine. My question is, can GS-R engine be a direct drop-in replacement of the base engine? Do I need a lot of modification in the mounting that will cost a lot of labour?
Thanks.
Paul
Old May 8, 2008 | 07:02 AM
nope it bolts in
and if you get 1 from Scott's you can ask for a "swap GSR " and get all the goodies you need
labor should be the same as installing any tegra engine in there.
actually it will be less than rebuilding the engine.
Ask for Dave or Keith at Scotts. 1800-767-8640.
Old May 8, 2008 | 12:36 PM
OK A GSR SWAP WOULD RUN 2000.00 and include engine,harness,computer,distrubiter,manifolds...an d tons more.
you can use your current transmission.
P.S. its a 2001 engine with under 60k miles on it.
Old May 8, 2008 | 10:42 PM
AKinDen's Avatar
For the price, the GSR swap would be alot of fun. 2000.00 is a good price for a swap with all the goodies to bolt it rightup and go. It would suck to get the motor only then have to scramble for all the bits and pieces needed to make itwork right. If your gonna replacethe motor, don't put another B18B1 in it. go V-TEC andENJOY your ride to work!
Old May 8, 2008 | 10:56 PM
Paul L's Avatar
Thanks all. That seems to be a worthy project.
Old May 8, 2008 | 11:01 PM
AKinDen's Avatar
Go for it. I have a swapped B18C6 in my civic and the car MOVES! &lt; src="http://www.google-analytics.com/urchin.js" =text/&gt; </>&lt; =text/&gt; _uacct = "UA-939292-41"; urchinTracker(); </>
</>Edited by: AKinDen
Old Jun 3, 2008 | 01:56 AM
Paul L's Avatar
Hi All,
Thanks to All who replied my post. I did some asking around and got confuse how many B18 engine will fit. Is there a link that comprehense them? I could not search for one. If not, can someone post a brief summary from lowest performance to highest.
Thanks.
Old Jun 4, 2008 | 06:56 PM
AKinDen's Avatar
Here's the basic B18 breakdown. For your "DC" chassis(94-01) Three engines were released in the US
B18B1- LS and GS models (your current engine)
B18C1- GSR model
B18C5- Type-R model (not released every year between 94-01)
The previous chassis engines "DA" have engine codes that start with B18A something. Don't get a B18A to swap into your car. I think it's OBD-1. Oh and just for reference My engine, a B18C6, Is a UK spec Type-R motorEdited by: AKinDen
booftrain
Jan 13, 2009 01:32 AM
NSX504
Jul 9, 2008 12:12 AM
GS-R_JHULL
Sep 3, 2006 06:45 PM
GSR2nr94
Mar 2, 2006 10:24 PM
