92 integra wont go into gear ?
Old Dec 15, 2012 | 07:24 AM
acurateg32's Avatar
Default 92 integra wont go into gear ?
ill try to keep this short without missing key points.
ive got the ys1 trans usdm mounted to a b18a1.
Car started hard and i mean HARD shifting into 1st and sometimes 2nd but was still drivable. if i pressed on the gas more than half throttle it would high rev and creep to speed. (to me indicating a slipping clutch?) i adjusted to the trans cable and it stopped the noticable slipping.
the car about a couple months later would not go into any gear as if the shift linkage was disconnected. lifted the car and shift linkage moved very easily.
but externally looks fine.
drained some fluid and no metal flakes.
took on the plug higher up on passenger side of trans and found very fine metallic dust.
had some shade tree craigslist mechanics install a new clutch disc (oem),throwout bearing and release bearing but reused pressure plate and flywheel.
still will not grab any gears. i can run the car through all gears without pressing clutch with the engine running.
never made any noises or grinds except downshifting into 3rd, which i heard is normal for hondas.
fresh acura mtf. but the weird thing is the old clutch disc isnt even that beat up. all the springs are in tact and everything.
is the trans shot or could this be a easy fix?:scared:
Old Mar 18, 2024 | 11:38 AM
Kshehan97's Avatar
Wondering what the fix for your issue is if you found one? ive got a friends car who is having the exact the same issue.
krish727
Jan 12, 2016 11:40 PM
clboy97
Feb 23, 2009 01:14 PM
booftrain
Jan 16, 2009 08:55 PM
Aimskie
Aug 18, 2008 12:54 PM
