Window not working
'91 Legend 4 door (LS)
The passenger front window will not work with either the drivers window control panel or the passangers control. All other windows work.
I'm thinking the window motor. Any control unit or switch, or fuse I should check first?
$49.95 + S/H on E-bay; Good price? (Window motor)
Thanks for any and all help.
-Tom
ok, since neither the drivers or passengers switch works, i would guess that it is a motor issue, not a switch issue, unless both switches managed to go bad at the same time. here is a sort of ghetto check to see if the switches work. at night, turn the lights on, and turn the key on, but not the engine. push the switches that make the window go down, and see if you can detect any draw in power, such as a dim in the lights.
