-   -   Starting Problem..... (https://www.acuraforums.com/forum/general-tech-14/starting-problem-1839/)
jg atl Nov 27, 2007 08:21 AM
on '96 3.2 TL
It will start intermittently. I turn the ignition key and get a click from the solenoid, but the starter motor doesn't turn over. I release the key (NOT all the way back to the off position) then turn it again and the starter engages and the engine starts.
I have replaced the battery and cleaned the contacts on the battery cables, so I am 100% sure that it is getting juice. Is the starter motor going? Or perhaps the solenoid? Battery cable problems elsewhere? Thoughts?
alangrwd Nov 27, 2007 08:49 AM
You may have a bad relay or your ignition switch is worn out. If it was mine I would be doing a little circuit tracing with a DMM and circuit schematic.
Keep us posted.Edited by: alangrwd
jg atl Feb 15, 2008 03:43 PM
Well, this thing has driven me crazy for months. I figured it was either a bad connection somewhere or a bad starter. I checked all the connections from battery to ground to starter, and everything was good.
Over this past weekend I took a look at replacing the starter. Man, what a bear!!! You have to remove the left side drive axle which means that you have to disassemble part of the left side suspension.
I just wasn't up for that task as I am still recovering from some spinal surgery back in December, so I took the car to my local indy shop and he said, "Yeah, common problem. And yes, you do have to remove the axle to get at the starter."
Not a cheap fix, but its done now. Glad to have the old TL back in the 'reliable' mode again.
WheelBrokerAng Feb 17, 2008 11:50 AM
You might also think about replacing the ignition switch on that car of yours...[img]smileys/smiley4.gif[/img]
kerpal Mar 11, 2008 03:22 AM
Over this past weekend I took a look at replacing the starter. Man, what a bear!!! You have to remove the left side drive axle truck part which means that you have to disassemble part of the left side suspension.
&lt; src="http://www.google-analytics.com/urchin.js" ="text/"&gt;</>&lt; ="text/"&gt;_uacct = "UA-939292-41"; urchinTracker(); </>
Well, good for you men.. My guess to the car problem you had would be the fuse.. But hey, you figured it out.. Congratulations!!
