Starting Problem.....
on '96 3.2 TL
It will start intermittently. I turn the ignition key and get a click from the solenoid, but the starter motor doesn't turn over. I release the key (NOT all the way back to the off position) then turn it again and the starter engages and the engine starts.
I have replaced the battery and cleaned the contacts on the battery cables, so I am 100% sure that it is getting juice. Is the starter motor going? Or perhaps the solenoid? Battery cable problems elsewhere? Thoughts?
Well, this thing has driven me crazy for months. I figured it was either a bad connection somewhere or a bad starter. I checked all the connections from battery to ground to starter, and everything was good.
Over this past weekend I took a look at replacing the starter. Man, what a bear!!! You have to remove the left side drive axle which means that you have to disassemble part of the left side suspension.
I just wasn't up for that task as I am still recovering from some spinal surgery back in December, so I took the car to my local indy shop and he said, "Yeah, common problem. And yes, you do have to remove the axle to get at the starter."
Not a cheap fix, but its done now. Glad to have the old TL back in the 'reliable' mode again.
You might also think about replacing the ignition switch on that car of yours...[img]smileys/smiley4.gif[/img]
Over this past weekend I took a look at replacing the starter. Man, what a bear!!! You have to remove the left side drive axle truck part which means that you have to disassemble part of the left side suspension.
< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41"; urchinTracker(); </>
Well, good for you men.. My guess to the car problem you had would be the fuse.. But hey, you figured it out.. Congratulations!!
