RSX 03 Auto - Noisy Solenoid
Old Dec 3, 2008 | 08:54 PM
tdottony's Avatar
Recently bought an RSX 03 from a Honda dealership. I have noticed that
each time I slow down and brake or pick up speed there is a noticeable
clicking noise that I'm told is the activation of this security feature.
I've had mixed feedback from Acura service centres. Honda has been
useless. Some say its a feature of the '03 car, others say its way too load
and others that it should not be happening. I test drove others and did
not notice this.
This is a big miss by Acura if its standard. I do find it hard to believe that
for a car of this stature that this annoying noise is typical.
Any experience /comments from other owners.
Cheers
Old Dec 4, 2008 | 02:52 PM
megaman's Avatar
Sounds like it might be a bad/loose CV joint or a problem in the ABS system,also check wheel bearings.Have had all of these problems associated with a clicking noise.Sure isn't a normal sound no matter the car or age of the car.Good luck
Old Dec 4, 2008 | 03:53 PM
tdottony's Avatar
Its for sure coming from the gear area. They actually replaced the solenoid component. I still can't believe they think that its a normal noise ... boo to Honda/Acura.
Old Dec 4, 2008 | 04:31 PM
megaman's Avatar
Sounds like you need to find a btter repair source. I have a 91 integra with 250,000 miles on it,still running strong.There's a "ring" at the brake assembly that actuates the ABS.May be bad or loose.When I buy a car,I buy a Haynes and Chilton repair book.Between the two of them I can usually get the job done or at least they point me in the right area.Good luck.
jg atl
Oct 16, 2014 10:32 AM
idreamofthe60s
Mar 31, 2013 09:07 PM
amybryant420
Jul 7, 2011 01:12 PM
arslws
Dec 27, 2007 12:44 PM
