rear windows
to be honest with you, the best way to do it is to just do it. Take both door panels off. Take one apart and use the other as a visual as to where things go. It seems difficulty but it's very easy. the only other suggestion I can give to you is to buy a haynes manual. Those run $15-$20. However, if you are doing a conversion from manual to power window it is going to be a little tougher. If you are going to a junkyard for the parts, bring a digital camera and a pad of paper. Take a crapload of picks and notes as to how, and what order you took things apart. If you are buying it from a dealer, there should be instructions or have them copy the correct pages from their manual for you. They don't normaly mind to do that. Hope that helped.
