copyguy |
02-02-2006 01:51 PM |
to be honest with you, the best way to do it is to just do it. Take both door panels off. Take one apart and use the other as a visual as to where things go. It seems difficulty but it's very easy. the only other suggestion I can give to you is to buy a haynes manual. Those run $15-$20. However, if you are doing a conversion from manual to power window it is going to be a little tougher. If you are going to a junkyard for the parts, bring a digital camera and a pad of paper. Take a crapload of picks and notes as to how, and what order you took things apart. If you are buying it from a dealer, there should be instructions or have them copy the correct pages from their manual for you. They don't normaly mind to do that. Hope that helped.
