-   -   October is Fall National Car Car Month - Please Perform Inspection! (https://www.acuraforums.com/forum/general-tech-14/october-fall-national-car-car-month-please-perform-inspection-3860/)
Wipers123 Oct 21, 2009 01:12 PM
October is Fall National Car Care Month and I encourage everyone to take a walk around their vehicle and take a look at the common maintenance areas - many of which are quick, do-it-yourself (DIY) automotive maintenance items.
1. Tires: Check tire pressure, check treadwear, is it time for a rotation? Your correct tire pressures are listed right on the tires and on a sticker inside your driver door.
2. Bulbs: Check for any burnt-out bulbs - especially center/high brake lights (which seems to be an epidemic in the USA).
3. Fluids: Check all fluids under the hood. Most reservoirs have clear markings. Also check your oil change sticker to see if you're due.
4. Air Filters: Check your engine air filter and your cabin air filter. Replace if necessary. Yes - many vehicles have TWO filters which should be changed every 6-12 months depending on your driving habits and climate.
5. Windshield Wiper Blades: Inspect and replace your windshield wiper blades taking note that most should be replaced every 6-12 months.
Depending on your automotive maintenance skill level, there may be other things you should inspect/check/replace.
National Car Care Month serves as a reminder that vehicle maintenance leads to safer vehicles and safer roads as well as a more satisfying driving experience. Use this as a reminder to take a few minutes with your vehicle!
Jeff
President
Good Luck!!
WheelBrokerAng Oct 22, 2009 11:20 AM
Hello Jeff
1 Attachment(s)
I like your up and coming web site you put in here but I had to take it out.
Non paying ads are not allowed in any of our 50 web sites , BUT! The cost of placing ads on our pages is very low cost.
Try it out for a couple of months and you will see it works..
You can type your web addy as www dot 123 dot com (like This) and I will leave it in there, then it's not a direct link.
WheelBrokerAng :)
any other way is a reason to ban you...
