October is Fall National Car Car Month - Please Perform Inspection!
October is Fall National Car Care Month and I encourage everyone to take a walk around their vehicle and take a look at the common maintenance areas - many of which are quick, do-it-yourself (DIY) automotive maintenance items.
1. Tires: Check tire pressure, check treadwear, is it time for a rotation? Your correct tire pressures are listed right on the tires and on a sticker inside your driver door.
2. Bulbs: Check for any burnt-out bulbs - especially center/high brake lights (which seems to be an epidemic in the USA).
3. Fluids: Check all fluids under the hood. Most reservoirs have clear markings. Also check your oil change sticker to see if you're due.
4. Air Filters: Check your engine air filter and your cabin air filter. Replace if necessary. Yes - many vehicles have TWO filters which should be changed every 6-12 months depending on your driving habits and climate.
5. Windshield Wiper Blades: Inspect and replace your windshield wiper blades taking note that most should be replaced every 6-12 months.
Depending on your automotive maintenance skill level, there may be other things you should inspect/check/replace.
National Car Care Month serves as a reminder that vehicle maintenance leads to safer vehicles and safer roads as well as a more satisfying driving experience. Use this as a reminder to take a few minutes with your vehicle!
Jeff
President
Good Luck!!
Jeff
President
Good Luck!!
Last edited by WheelBrokerAng; Oct 22, 2009 at 11:15 AM. Reason: Non Paying Ads Not Allowed
I like your up and coming web site you put in here but I had to take it out.
Non paying ads are not allowed in any of our 50 web sites , BUT! The cost of placing ads on our pages is very low cost.
Try it out for a couple of months and you will see it works..
You can type your web addy as www dot 123 dot com (like This) and I will leave it in there, then it's not a direct link.
any other way is a reason to ban you...
RPMMARK
Oct 2, 2012 04:54 PM
RPM JEFF
Sep 22, 2012 11:32 AM
daygoVR6
Jul 5, 2010 01:43 AM
