New Member Questions Needing Help!
Got a 2000 Acura Integra ... just had it in for brake work, oil change and transmission fluid flush and fill, had to replace the radiator (the factory installed original developed a split seam and was losing coolant when theengine would warm up) ... in short, spent a lot of bucks ... now, the "Check Engine" light has come on ... any suggestions?
Also, the shifter on the center console doesn't shift anymore when you depress the brake peddle ... I have toinsert a small screwdriver in through the little slot in the console to get the shift linkage to unlock ... it's a real pain. Anyone out there have any suggestions?
Thanks
