Engine bucking HELP!
Old Apr 7, 2006 | 04:14 AM
acuraluvr's Avatar
Hey guys I have a 92 acura integra ls, manual, 1.8L.After 30 mins of driving holding a constant speed the engine will begin to feel like it is binding or bucking intermitently. After this as long as your driving the car the problem is frequent as a couple times every few min.I do have a check engine light (code 13) which indicates barometric pressure sensor. Is this my problem or does anybody think it's something else? let me know Thanks alot for any info.
Old Apr 12, 2006 | 03:19 PM
copyguy's Avatar
Member
only thing you can do is to go to a junkyard and rip a sensor out of one of their cars and put it in yours. Reset your ecu and give it a try. That should fix your problem. if not, let me know.good luck
Old Apr 17, 2006 | 04:20 AM
acuraluvr's Avatar
Hey, turns out it was bad gas. Corrosion in the tank. It seems you cant run a car off of brown gas. A new fuel tank solved the problem. The baro sensor is still giving code, but the car runs fine. The baro sensor is hardwired into the ecu, so guess I'll get one when I get around to it. Thanks copyguy. See ya.
Old Apr 17, 2006 | 11:54 AM
copyguy's Avatar
Member
thanks for responding back with fix. Dirty gas? who would have thought!
booftrain
Jan 13, 2009 01:32 AM
athome250@yahoo
Dec 17, 2008 12:23 PM
NSX504
Jul 9, 2008 12:12 AM
rnr568
Feb 12, 2008 11:40 PM
Landry
Jul 22, 2007 06:56 AM
