Clutch Bleed Issues -- 94 Acura Legend
Old Apr 24, 2010 | 10:44 AM
bigjohnmn's Avatar
Default Clutch Bleed Issues -- 94 Acura Legend
I recently obtained a 1994 Acura Legend GS Coupe, when I got the car the pedal would just drop to the floor, no pressure. I followed the trouble shooting guide in the repair manual and replaced the Clutch Master Cylinder, removing the old one and replacing it was a relatively simple task, after installation I went to bleed the clutch, nothing ever comes out of the bleeder valve on the slave cylinder at all, I have completely removed the valve, still nothing.
I also tried bleeding the system before I replaced Clutch Master Cylinder, nothing came out of the bleeder then either.
Could it be a bad Slave Cylinder? Is there an easy way to check if it is the slave? I think I might have jumped the gun replacing the Master Cylinder and want to better diagnose the problem before I replace the slave.
Any advice would be great.
Old Apr 25, 2010 | 01:15 AM
jacky2010th's Avatar
I also got the same problem, but I have resolved it with the help of local car mechanic and got pressure back.
Old Apr 27, 2010 | 01:32 PM
Cool # 2 Spam Post Jackie
This is number 2 for you..No more Spamming the forums...
Old May 18, 2010 | 04:30 AM
Samohajo@yahoo.com's Avatar
My thoughts would be the previous owner filled it up knowing there was a leak somewhere. You dont need to bleed it unless it was just changed recently, air doesn't just get into that system mysteriously. I would go to a tranny shop that does a free inspection and see what the problem is and then determine if you can tackle the job yourself or let a professional repair it for you.
You too PINHEAD..no more Spam or stay out of the forums..
Nephew Monty
Jan 6, 2009 05:15 PM
legendk15
Dec 19, 2008 12:08 PM
Imtiaz
Dec 8, 2007 10:33 AM
justin96
Nov 28, 2006 02:12 AM
chet059
Dec 27, 2005 02:39 PM
