Acura CL 3.0 starting problem
Old Jan 20, 2010 | 03:43 AM
lanejared's Avatar
Default Acura CL 3.0 starting problem
I had to turn the key several times to get the engine to start.
The clutch is fully depressed, but there are no relay clicks or any other noises.
After six or seven cycles of the key, it started. This has happened once or twice before, pretty randomly.
The battery is recent. In checking the manual, there is a "clutch interlock switch" mounted to the clutch pedal bracket.
Is this par of the starting circuit ?
Any guidance is welcome.
Old Feb 12, 2010 | 02:44 AM
martizt's Avatar
The car will sometimes not start because of a problem with the ignition switch. check with dealer.
jg atl
Mar 11, 2008 03:22 AM
91gsteg
Nov 4, 2007 09:18 AM
greenmoneypit
Aug 4, 2007 05:17 AM
viking
May 25, 2007 07:36 PM
duane
Mar 27, 2007 06:12 PM
