87 integra fuel management
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
[img]smileys/smiley10.gif[/img] Hi, The problem persists....smog test revealed rich on idle and higher rpm.found two bad injectors-replaced.replaced ox sensor, mechanic checked other sensors-deemed ok. Rain leaked in and drowned "brain under passenger seat-replaced. ign timtming on, fuel press ok, compression ok.get 31 mpg and I`m afrain sincw it used to get 37 mpg its senseless to take it for a smog check. any advice? ?
thx
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
THE TEST IS REQUIRED FOR TRANSFER OF OWNERSHIP.THE GAS MILEAGE HAS DROPPED IN ONLY SIX MONTHS.ACTUALLY EVER SINCE I STARTED HAVING TROUBLE WITH THE TWO BAD INJECTORS.SORRY FOR THE DELAY IN ANSWERING, MY DAD PASSED AWAY ON THE FOURTH OF APRIL AND I`VE BEEN TOO BUSY `TIL NOW.THANKS FOR THE REPLY[img]smileys/smiley16.gif[/img]
HEY Patrick, still around? 220,000 miles on my "problem". It doesn`t start up immediately like it used to, and I can see its really rich on start up-wiffs of black smoke-unburned fuel.Again, this has a warning light occasionally, code says "oxygen", and I put a new ox sensor 500 miles ago.
thx SMYLIE
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
turbonatormr2
Mar 8, 2010 03:32 PM
klopot187
Jun 5, 2007 01:17 AM
