< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> [img]smileys/smiley10.gif[/img] Hi, The problem persists....smog test revealed rich on idle and higher rpm.found two bad injectors-replaced.replaced ox sensor, mechanic checked other sensors-deemed ok. Rain leaked in and drowned "brain under passenger seat-replaced. ign timtming on, fuel press ok, compression ok.get 31 mpg and I`m afrain sincw it used to get 37 mpg its senseless to take it for a smog check. any advice? ? thx |
as engines age, they naturually get worse mileage....do you live soemwhere that the test is required?
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> THE TEST IS REQUIRED FOR TRANSFER OF OWNERSHIP.THE GAS MILEAGE HAS DROPPED IN ONLY SIX MONTHS.ACTUALLY EVER SINCE I STARTED HAVING TROUBLE WITH THE TWO BAD INJECTORS.SORRY FOR THE DELAY IN ANSWERING, MY DAD PASSED AWAY ON THE FOURTH OF APRIL AND I`VE BEEN TOO BUSY `TIL NOW.THANKS FOR THE REPLY[img]smileys/smiley16.gif[/img] |
my condolences on the passing of your father. i wish that i got anywhere near 37 mpg...how many miles are on the vehicle? |
HEY Patrick, still around? 220,000 miles on my "problem". It doesn`t start up immediately like it used to, and I can see its really rich on start up-wiffs of black smoke-unburned fuel.Again, this has a warning light occasionally, code says "oxygen", and I put a new ox sensor 500 miles ago. thx SMYLIE < => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> |
