problems with my 91 integra
Old Sep 8, 2006 | 05:33 AM
blk_integra's Avatar
I started my 91 acura integra and i drove about 2 miles down the road. as i was in traffic i let off the brake and went to accelerate and nothing happend. i pulled to the side of the road and i tried to re-start the car, but after i let go of the key it died. i checked my oil,water and fuses inside the car, but i was wondering if this problem could be a main fuse because all of my power locks and windows wouldnt work, as well as the shifter. has anyone had any similar probelms, or have any advice for me?
Old Sep 18, 2006 | 11:22 AM
Sounds like a main buss fuse to me could also have broke a ground wire on the engine.
ALSO CHECK:
fuel pump pressures
fuel filter
coil spark output
batt terms
bad gas
If you find out what it was please post the answer here.
Old Sep 18, 2006 | 06:58 PM
acutaly it was my ignition switch, and lock cylinder along with the rotor nad distributor cap. but thanks for the reply...
jdmintegie
Feb 10, 2010 06:07 PM
acura_kris
Apr 1, 2009 08:01 PM
xixi
Feb 8, 2009 09:27 PM
johnnyz
Nov 8, 2006 07:38 PM
