just got a 97 3.0 CL and i am hearing a ticking noise more and more the faster i go. this isnt the CV joint/boot cause it doesnt click when i turn. its just when i am going straight.
tick tick tick as i drive and stops at a red light. also, my speedometer jumps 20mph every so often and the guy at the mechanic shop said it might be the speedometer cable and i am not sure if thats what the ticking is coming from. he said it might be. true??? i am a new member here aswell with another forum and nobody replys to my threads there. not sure if its the forum or what, but i have posted many threads..... all advice is appreciated.... |
m pretty sure you dont have a speedo cable
roll down the windows and try to figure out if its a inside or outside noise. it very well could be your cluster assembly thats ticking. also a rock stuck in a brake rotor vent can tick twine wrapped up on a axle nail in a tire antenna motor that wont stop running fuel purge solinoid no longer on its mount can tick too. i have had NEW axle assemblys tick for a bit, and same with worn wheel bearings |
| All times are GMT -5. The time now is 04:05 AM. |
