-   Canada, Over Seas & Elsewhere (https://www.acuraforums.com/forum/canada-over-seas-elsewhere-41/)
-   -   Cr encyclopedia with Acura page (https://www.acuraforums.com/forum/canada-over-seas-elsewhere-41/cr-encyclopedia-acura-page-6304/)
WheelBrokerAng Apr 4, 2010 09:24 AM
Happy easter to all our members
2 Attachment(s)
i'D LIKE TO WISH ALL OF YOU MEMBERS A Happy Easter
Thank all of you for being members in our forums...
Now Eat Turkey and enjoy :D
WheelBrokerAng..and Family :) :) :) :)
jhonny.drift Jun 15, 2012 07:40 PM
photo, info, video
What did that mean.?
kubadude Jul 31, 2012 10:14 PM
I just bought a 02 acura tl its having tranny problems
the car is great but as soon as i heats up it dies by that i mean wont shift when the car is cold it shifts fine now the car sat for two day still drives fine but no reverse what would happen if i changed the tc or could it be an electrical proble:confused:
Codyion Aug 23, 2012 05:12 AM
It's good if you drive this Acura on a smooth road. Change the wheels of the car in between if you hear any noise. Sometimes wheels also causes tranny problems in between.
jg atl Aug 23, 2012 08:44 AM
How is the fluid level in the tranny? That is the first thing to check. How many miles on the car? Has the tranny fluid ever been changed? How about the filter? Those would be the next two suspect areas. After that, you are in for some serious repair work.
Transmission are the one weak area of these cars.
Maxweller Sep 1, 2012 02:23 AM
You should check for tranny features if you are buying an Acura car. Thanks for the posting. I will definitely keep these things in mind before buying this car. At least after buying this there will not any risk that you will be encountered with any problem.
Curtiss Sep 15, 2012 01:42 AM
How many KILOMETERS do you guys get ?
i get about 300-350km MAX ...
everytime i go to the pump I'm like... uhmm i'm gonna try to eco-drive ( never over 3k rpm ) as soon as i start the car i'm like **** that... rev the CAT... AHHHH ****ing annoying i wish i could get 500km out of a tank....
RL3.5 Sep 17, 2012 03:42 PM
Steering column tilt motor
2000 RL 3.5. The steering wheel tilt motor seems to have gone out, but telescopic works. Been told by one Acura mechanic so far that he can't get one, but if he did he has to order the entire steering column at about $2700 not including labor. Does anyone know if there is another way? Getting just the motor? Or where to get a steering column? Or at least a way to force my tilt down until I can fix? It's stuck in the up position. Thnx.
RL3.5 Sep 17, 2012 04:04 PM
Tilt steering
....OK, I think I found that there is not actually a tilt motor, but I did find a tilt and telescopic sensor. Does anyone know if that's all I need? Otherwise it looks like I may have to replace the column assembly. Any help with where to find cheap parts?
DirtbikeJohnny Sep 19, 2012 05:51 PM
New member ---I NEED HELP!
I am a new member searching for a solution for my 1994 Acura Vigor w/85k miles, auto trans.
Here's what happened...was driving and all of a sudden, it started to die, like it ran out of gas. I got it started and put fuel in the tank (it was low) and drove it home. Came out an hour later and the car started fine and ran for 15 minutes and died again and I could not get it started and I had to push it home.
So, I bought a fuel filter, replaced it and the car starts fine, also, I pulled apart the main relay & soldered all the tips in it. I took the EGR tube off and made sure it was clear. I even bought a fuel pressure regulator and it still has a huge hesitation over 1500rpm. I sprayed the throttle body w/carb/fuel injection cleaner. The car will start & idle fine, and slowly rev up, but while driving, under load if i go over 1500-1800 rpm, it bogs down & dies. There is no check engine light on. The fuel pressure is good too btw.
I am stumped :mad:...Any help would be greatly appreciated. Thanks in advance.
-DBJ-
