94 Acura Vigor hesitation HELP!
I am a new member searching for a solution for my 1994 Acura Vigor w/85k miles, auto trans.
Here's what happened...was driving and all of a sudden, it started to die, like it ran out of gas. I got it started and put fuel in the tank (it was low) and drove it home. Came out an hour later and the car started fine and ran for 15 minutes and died again and I could not get it started and I had to push it home. So, I bought a fuel filter, replaced it and the car starts fine, also, I pulled apart the main relay & soldered all the tips in it. I took the EGR tube off and made sure it was clear. I even bought a fuel pressure regulator and it still has a huge hesitation over 1500rpm. I sprayed the throttle body w/carb/fuel injection cleaner. The car will start & idle fine, and slowly rev up, but while driving, under load if i go over 1500-1800 rpm, it bogs down & dies. There is no check engine light on. The fuel pressure is good too btw. I am stumped :mad:...Any help would be greatly appreciated. Thanks in advance. -DBJ- |
Like it
These kind of post is always inspiring and I prefer to read quality content so I happy to find many good point here in the post, writing is simply great, thank you for the post.
buy google +1 votes |
acura tl 2006 acura rsx-s acura of lynnwood acura integra parts acura vigor ... acura johnson city acura cockapoos 94 acura integra acura of portland acura
auto shipping car shipping auto transport |
| All times are GMT -5. The time now is 12:59 AM. |
