I'm curious about what data the trip computer can display. We just test drove one a couple of hours ago but didn't remember to check it then.
The dashboard output data are as follows:
1) average miles per gallon 2) instantaneous miles per gallon (it updates every second while you drive) 3) miles until empty (seemingly poor estimate though) 4) trip timer 5) miles-traveled recorder (besides the odometer) 6) average speed 7) oil life 8) outside temperature You can reset numbers 1, 4, and 5 to have them recalculated. For numbers 1 and 5 above, you have two separate records so you can record your overall values as well as your values for each individual trip. I would imagine you can also reset number 6 as well, but I never tried it. |
Also, there are: Oil life (dunno how that works, but I see it often) Tire pressure (with individual pressure for each tire) All sorts of warnings (doors/trunk ajar, passenger seat belt not fastened when there is someone on that seat, fuel low, handbrake on while u drive, etc etc) You can also use it to change settings such asspeed forautomatic lock of all doors,if u want just driver door or all doors unlocked when shifting back into Park, auto headlight on sensitivity, and such. |
What year model did you test drive?
2009 tsx automatic base model (US).
