Has anyone used their ipod via the standard auxiliary jack?Does it lock out control of you ipod when plugged in?
< src="http://www.google-analytics.com/urchin.js" =text/> </> that is the only way that i use my ipod in my car and i have yet to have a problem with it. my ipod works fine while it is plugged in. < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
What about a Zune? I need to get an auxiliary cable connected somehow.
they both work about the same way so i dont know why it wouldnt work.
they have a head phone jack to plug into so it should work. just go to best buy and get a $10 aux cable (i personally got a sony one that was $25 and it works alot better then a dynex), but once you plug that into the the head phone jack in your Zune plug the other end into the aux jack and set the radio to aux and everything should work fine. let me know how everything works out for you. |
Okay, i started this thread before I bought a TSX waaay back in september 07. If you're wondering, FastTSX is correct. It works fine. But, like he said, be sure to buy the more expensive cable ($30-$40) because the cheap ones are reliably unreliable... they short out.
| All times are GMT -5. The time now is 09:13 AM. |
