My 2006 TSX has started making a slight dragging sound especially in 3rd gear. It is noticeable after letting off the gas to slow down. My car is an AT (I use the manual mode mostly) and it has 22000 miles. I check the fluids once per month and change the oil in 5000 mile intervals. I drive a little roughly though. I use the gears a little more but I never redline. In fact, I don't go past 5000 RPM. Do you think the rough driving has anything to do with it? Should I bring it in?
< src="http://www.google-analytics.com/urchin.js" =text/> </> i have a 06 also with the auto/manual. i drive mine hard and i mean hard, especially when i am in manual and i have redlined it and bounced the needle more then a few times but i have never had any problems with anything and i have 28000 miles on the car. i would take it in and have it looked at. i heard when i first got the car from a buddy that worked for acura service that sometimes the transmissions will do that and they will make that sound and feel like it is holding back. i would take it and get it looked at. |
