My door lock on the passanger side front door - is not working with the key open button or inside the car button - I must lift it up with my fingers to make it work... Does anyone know - is this a problem that can be fixed easy or do I have to bring it in. please advise ... It is a 04 TSX with 40,000 miles and runs like a top..RL [img]smileys/smiley19.gif[/img] |
Door lock Broke - 2004 TSX 400000 miles passenger side - front door - it will not go up or down with the inside switch or the key button.. is this a big problem or maybe something I can fix - please advise ...rl [img]smileys/smiley19.gif[/img] |
SOUNDS like the latch/electric solinoid has failed.
it could also be a power issue with it. can you remove the door pannel and hotwire the lock solinoid and see if it works? do a test light to the door harness and see if the thing is getting power when your trying to lock it. |
