AT Trasmission Fluid Replacement
Old 02-11-2009, 11:52 AM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
if (SymReal == null)
SymReal = window.;
window. = Sym;
SymInitWinOnload()
if ( SymRealOnLoad == null )
return SymOnLoad;
window.onload = SymInitWinOnload();
The Acura dealer said there is a cap-screw on the top of the transaxle that can be removed to add AT fluid after draining the existing fluid. Is this correct? Approximately where is it?
2003 TL (not Type S)
Old 02-11-2009, 01:23 PM
it is true its a huge 17mm bolt about the size of a silver dollar coin.
if you are standing infront of the car with the hood open.
the firewall is the 12oclock position and the driver side front tire is at 3o clock. its at 2oclock and way down on top of the transmission and it points straight up.
pulling the air box upper assembly from the engine will make it asd plain as day.
Old 02-11-2009, 01:42 PM
please please make sure you use the correct type of transmission fluid. and dont stick a plastic funnel in there if the transmission is hot. it can melt into the transmission.
P.S. dont ask how i know this.
Old 02-11-2009, 02:33 PM
Many thanks. I'm sure I'll be able to find it, and I don't even like to work on cars when they are hot, so I don't think I'll melt a funnel to the upper casing of the transaxle...however, I have also done similar things to which I will not readily admit.< =""><!--
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
SymInitWinOnload()
return SymOnLoad;
Old 02-11-2009, 03:43 PM
i melted mine into the internals of the transmission.
4k worth of tuition payment there.
Old 02-15-2009, 12:04 AM
Yes yes MAKE SURE YOU USE ONLY</span> ACURA ATF
That is one of the most common causes of transmission failures. People take their cars somewhere else and get the transmission fluid changed.
When people come in with a transmission problem... that is the first thing we ask. And it is the most common cause.
car_nut
08-27-2008 01:16 AM
TL2005
03-03-2008 01:04 PM
nikademo
09-27-2007 11:36 AM
awp1965
05-02-2006 12:59 PM
BigReese
04-18-2006 06:32 PM
Quick Reply: AT Trasmission Fluid Replacement
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
