removing the rear door
Hello, I need to remove the rear door of my 2003 3TL. I need to transport a cabinet. The cabinet will fit in the back seat but to get it in I must remove the door. My concern is putting the door back on. In the good old days realigning a door was a pain with the mounting plate in the pillar swimming all over the place. Is it just a matter of rebolting the door on these days. If you understand my question. Access to the bolts is very easy. I was going to remove door then put it back in the opening then bolt it up.
Sounds crazy but.................thanks/ |
| All times are GMT -5. The time now is 03:47 AM. |
