-   -   No Spark (https://www.acuraforums.com/forum/tl-16/no-spark-2980/)
Outrun Nov 12, 2008 02:50 PM
<DIV id=post_message_1399956 itxtvisited="1">I have a 96 2.5 TL . The fuel pump is working, but there is no spark from the coil. I have 12v on the Blk/Yw wire going to the coil. This is the only wire that has voltage. When I unplug the igniter and turn the engine over there is no voltage on any plug terminal. Any ideas?</DIV>
acuralegend Dec 17, 2008 12:27 PM
replace the distributer assembly the pick up sender or coil or igniter has gone bad.
very common issue.
