-   -   Jarring Noise, HELP! (https://www.acuraforums.com/forum/tl-16/jarring-noise-help-2126/)
tigermac Feb 14, 2008 12:56 AM
Have 94 Legend. Every time I shift gears, I always hear a jarring noise like something is grinding. I suspect its the axle assembly. I already have a replacement for it but my question is.. is there any other thing I need to have available before I turn it over to the mechanic. I rather have my own parts.Comment much appreciated. Please also check this online Acura Parts store.
< ="text/">
Edited by: tigermac
jg atl Feb 14, 2008 08:41 AM
Grinding sound could also be wheel bearings. If it is, there is typically a difference in the sound when you turn one way or the other. If you load up the side of the car with a bad wheel bearing, the grinding/rumbling sound will get louder.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41";
