-   -   HID Conversion (https://www.acuraforums.com/forum/tl-16/hid-conversion-3861/)
lioneljoseph969 Oct 21, 2009 08:01 PM
HID Conversion
Hi All,
I'm new to the forum and would like to say that I have come across alot of interesting topics covered here.
I have a question I would like to ask the member. I have a 2002 3.2TL and was wondering if it was a easy process to replace the OEM HID lights with a Slim Line HID aftermarket system? Could I use the existing relays to handle flicker and just splice the connections for the new Slim Line balast that I would install in the same position as the OEM balast onto the existing wires. Is this recommended or not. I find that the OEM balast are just too expensive @ $350.00 each from Acura.
Hope to hear from someone soon as I have to repair one of my non functioning balast.
WheelBrokerAng Oct 24, 2009 11:37 AM
Hello New member..Welcome to the forums.
One of us will look into this for you shortly..
lioneljoseph969 Oct 27, 2009 11:51 AM
HID Conversion
Thanks for all the viewers of my post but I have figured it out myself. All I need to get is a D2R/D2S HID conversion kit or buy the connector from the Ballast to the bulb seperately for around $50 bucks. I can use my existing OEM wiring harness in the car already.
I do have another question though. Does anyone know the type of connector that plugs into the ballast? I would like to get the mating connector if at all possible so I don't have to butcher my OEM wiring. I would much rather create wiring adapters of my own so that everything can be returned to its original state if necessary in the future.
melodic Jan 14, 2010 11:09 PM
I have the whole passanger light out
I had the dealer ship try to replace the bulb and that did not do it. Now they are saying I need some other controller piece that is like 650.
there has to be a better solution.
can you give more info on what kits are available i have a 20033.2TLwith nav
thanks for your help.
greattik Feb 11, 2010 12:55 AM
If you are nervous about installing it,it is easy and you don’t even need directions. Just take it all out of the box and start plugging it in and you will see each plug only goes in one way so no mistakes are possible.
martizt Feb 12, 2010 02:27 AM
Yes,you can use the existing relays to handle flicker and just splice the connections for the new Slim Line balast that you can install in the same position as the OEM balast onto the existing wires.Good luck!
