When replacing the front engine mount on a 2003 TL, is it necessary to bleed the system? I know the mount is hydrolic, and I observe a line going into the bottom of the mount, but I don't think that line could be for liquid hydrolic (not heavy duty enough).
no it does NOT require bleeding that tube is a vacuum hose
that goes to the mount control valve. just make sure to hook it back up. |
Many thanks.< =""><!--
var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; if (SymReal == null) { SymReal = window.; window. = Sym; } } SymInitWinOnload() { if ( SymRealOnLoad == null ) SymRealOnLoad = window.onload; return SymOnLoad; } window.onload = SymInitWinOnload(); //--> </> |
