I have 96 acura TL, I just change out the spark plugs then 2 days later then
engine is stalling and can't rev over 3000 rpm the engine light is on, so i took it to autozone to pull up the code. then it pull up 6 codes one of them is po335 (crankshaft position sensor) so do i have to change out the sensor? but its $350 for the sensor!! |
| All times are GMT -5. The time now is 05:52 AM. |
