crankshaft position sensor problem help!
I have 96 acura TL, I just change out the spark plugs then 2 days later then
engine is stalling and can't rev over 3000 rpm the engine light is on, so i
took it to autozone to pull up the code. then it pull up 6 codes one of them
is po335 (crankshaft position sensor) so do i have to change out the sensor?
but its $350 for the sensor!!
