ChangedTheClockLight...ButNowIHaveThisProblem...No
ClimateControl thanks to the great instructions here on how to change the clock light, i did the job today. wasn't so bad. one hour of so. changed the light for the temp control display too (the right side one was out). i thought i had plugged in all 5 of the connectors in the back. now the auto temp control (no a/c, i turn the knob to auto no cool air) is not working along with the "outside temp" display ( it displays - - -). which connector do i need to re-check? i went from super happy to wow, what did i do? thanks for all your future help, joe ------------------ updated info- the fans stay on in auto mode and air is blowing, but the air is not air conditioned cool. so i need instructions on getting the outside temp to display and how to get my cold air back. thanks everyone! joe __________________ 2000 TLHot Wheels Collector Site |
you might be low on r134 every system has some type of leak alot of use just dont know it. if its over filled it want blow cold either same as if it low.
| All times are GMT -5. The time now is 07:24 AM. |
