Anyone else have this PROBLEM
i have a 99 TL i was driving on the highway 2 weeks ago and when i let off the gas pettle, my car shut off (as if i turned the key off).
i pulled over put in park re- start dies , 2nd try work dies 5 mins later , and then i was fine for like 2 weeks did it twice again yesterday.
any one know wut could cause this???????????
i would bet 1 of 2 things.
1 ignition switch.get it running then wiggle the keys up and down and side to side (without turning the key)
if it dies then bingo.
the other is a distrubiter.
when it is dead do you have spark?
do you have fuel.
as the hot weather starts hitting us them main bus relays start dieing.
hope this helps.
do you have fuel.
hope this helps.
i actually had the same problem, but with my RSX. i was driving and the engine died for a sec then came back on. i didn't know what was going on. then the next morning the car did it a few more time on the way to work, definitely not the greatest feeling. i took it to get looked at, and the mechanic told me that the onboard computer was acting up, and needed to be restarted. so they did that and i haven't had any more problems since. that was about 7 months ago. they told me it would eventually need to be replaced by acura, but not to worry about it until it acted up again. hope this helped
