-   -   Adding a Navigation System?? (https://www.acuraforums.com/forum/tl-16/adding-navigatin-system-659/)
Newt121 Oct 28, 2006 06:25 PM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Hi Guys,
I have a 2000 Acura TL. I want to add the navigation system to it. Can it be done? What will I need to do it if I can??
Thanks
Dan
nisreo Nov 9, 2006 02:08 AM
you will need to swap the wiring harness, update your pcm, add a nav
unit, screen and run all the new wiring. Its not something that we will
even do at the dealership. Your much better off going with an
aftermarket unit.
thanks
-Brian
wayneTN Nov 29, 2006 02:34 PM
It is possible and has been done. Here is a pretty good DIY article on it. http://tl.acurazine.com/forums/showthread.php?t=114084
