Hello y'all
i have a small problem, i hope. On my dashboard i have "maintenance required "light on. Can i remove it &How? Thank you in advance |
Hello,the directions are in the user manual if you have that handy. I believe with the engine off turn the key all the way but do not start the engine. Press and hold down both the buttons that reset your trip meter and the other, can't remember what it is. Hold them both down for 10 seconds and you will see the maintenance light go out. Hope this helps |
| All times are GMT -5. The time now is 03:48 AM. |
