-   -   08 TL 3.2 Sometimes Revs up and down when sitting in park or drive (https://www.acuraforums.com/forum/tl-16/08-tl-3-2-sometimes-revs-up-down-when-sitting-park-drive-6694/)
jpeterson Aug 14, 2013 03:46 PM
Hey i just purchased an 2008 acura tl a little more than a month ago. The car runs perfect other than this one problem that just started. When im sitting still the rpms will go anywhere from 600rpms to 1100rpms. I talked to my brother briefly and he seems to think a dirty throttle body. A friend said mass air flow senor but i feel that would throw a check engine light, which there is no check engine light on. I was just wondering if anyone has an opinion on what it could be. I haven't checked the throttle body yet. Im thinking about putting in a cold air intake too.
poorman212 Aug 17, 2013 11:30 AM
Does this seem to happen only once the engine reaches normal op temp or does it happen only when cold?
A good cleaning of the TB is never a bad idea. A can or two of cleaner, a few rags and a bit of time.....be sure to get both sides of the butterfly....also an old tooth brush makes quick work of this job.
jpeterson Aug 17, 2013 04:51 PM
It tends to do it more when cold but it has done it when fully warmed up. I will definitely clean the TB and see if it stops.
