< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> Any thoughts people....my baby seems to jerk alot when i slow down at a light or take my foot off the gas and coast, usually in 3rd or 4th gear.....any thoughts??? |
Hey man, I have an 02 TL and I had about the same problem as you but my car wld jerk sometimes after I took off and as it came out of 2nd into 3rd. I took it to the dealer to complain and they recommened a transmission flush to solve the problem. I left my car with them one after noon and the problem was sloved and it hasn't returned. Try a transmission flush and see if that works. It did for me.Edited by: collegeboy32 |
You have to be careful about the transmission flush. If the car is very old, and the transmission fluid has never been replaced, sometimes transmission fluid change results in giving more problems than solving it. The transmission fluid acts also as a detergent and it takes all goo off of all the little places inside the transmission, which can then get stuck somewhere else that could be more disastrous than before. All I am saying is that exercise caution. Ask a dealer or a mechanic (preferably someone other than the guy or place that would actually do the transmission fluid change or else they would be biased) if the tranmission fluid change would help solve the problem. Thanks. --- Shah Used Cars Houston |
You didn't mention how many miles you have on your car. I have heard urban legends about flushing the transmission on high mileage cars. If you have less than 50,000 miles I don't think there should be a problem. If you have over 100,000 I would be careful about doing a flush. Good Luck |
Sounds like a tranny issue. These cars are known for bad transmissions.
