I was wondering if it was possible to swap my Auto for an 02 CL-S's manual. Do you think it would fit?
yes.it wont be easy and your going to have to look into computer issues as well
What kind of computer problems? say i got to a shop that specializes in transmissions, would they take care of it?
Im betting the issues you would have could be fixed by putting in a manual transmission with its engine harness and manual computer.
a auto comp in a manual will throw all sorts of codes. like... converter lock up internal slippage possiable speed sender vehicle abs codes. cuz it says its in park but your moving etc... not a big deal just make sure to get all the goodies from a doner vehicle. shift linkage pedal assembly clutch master/slave and lines ALL engine bay harness ECM and transmission comp if it has one. flywheel, clutch ,and all that stuff better grab motor mounts aS WELL. |
