-   Suspension (https://www.acuraforums.com/forum/suspension-31/)
-   -   Strange Front Tire WEAR (https://www.acuraforums.com/forum/suspension-31/strange-front-tire-wear-3619/)
Greg105 Jul 11, 2009 10:13 AM
I have an 07 MDX with 40,000 miles. I just noticed both front tires are getting chewed up about 1 1/2 inches in from where the outside tread starts. Its on both sides of the tire and on both front tires. The tread in the middle between the two areas gettig chewed up is in great shape with another 10 to 15,000 miles of tread life left.
The car is going to the dealer Monday, but was wondering if anyone has an idea what is causing the problem. I want to be knowlegable when I go to the dealer on Monday if they say it is an alignment problem.
rsxsblue_1 Jul 11, 2009 01:42 PM
0tires are supposed to wear in the dead center in and out. The mdx is an all wheel drive vehicle. The camber could be off or it could need an alignment. tell them to check your toe in.
jws1112 Jul 22, 2009 09:16 AM
I have a 2003 Acura TL-S with a similar problem - both front tires with 30K miles or so are wearing on the outside edge (both inside and outside). Greg105, did the dealer find anything for your MDX?
WheelBrokerAng Aug 1, 2009 02:08 PM
Hi Members
Are either of you members rotating your tires every so often like three to 6 times a year.
I rotate mine evey other oil change. about 6,000 miles
WheelBrokerAng :)
boosted475 Aug 4, 2009 02:06 PM
and making sure your tires are inflated properly make a huge difference.
In tread wear and gas mileage!
WheelBrokerAng Aug 5, 2009 03:43 PM
Boosted 475 has got that right..why do you think they put
those TPMS's on all the new cars tires?
Is there any one that didn't know about TPMS?
WheelBrokerAng :)
boosted475 Aug 5, 2009 04:12 PM
yup I checked my tpms at least once each time I got in the car
WheelBrokerAng Oct 6, 2009 12:10 PM
Hello Member
Is that right, would you mind telling us all how you do that?
boosted475 Oct 7, 2009 01:19 PM
Ummm.. I push the info button on my RL's steering wheel until I see my tire pressures show up on my display???
