Need some help
I recently purchased a 88 integra and was curious if anyone could point me in the right direction to where i could find some decent suspension components or what to do.. Just wish it had shock/strut assembly on all four corners. idk can anyone help.
Hello New Member
1 Attachment(s)
I moved you down to this forum where you can get help..Please make sure you post in the correct forums .
Thank You! WheelBrokerAng |
Hello Member
I have yet to see a lowering system for that old of Integra...
Let me know if you ever find any... |
hhmmmm
is there any way of swapping from a newer integra or a different honda that has a coil spring/shock combo.???
(Post 9626)
Let me know if you ever find any... http://www.eautoworks.com/product-Gr...ntrol-4451.htm |
I would suggest OEM to reduce any more wear to your vehicle. Because it is an Older car using the part specifically made for it would increase the life span.
http://acurapartswarehouse.com these guys have pretty good prices on parts and cool features that let you save your car so next time you visit the site your car is already there. |
Hi
Why dont u try www.autopartsway.ca .Its really cool and the prices are really cheap. |
Need some help
Before I installed joomla, I installed other CMS via cpanel-fantastisco. The installation is very easy, but I dont like that CMS so I decided to installed joomla via cpanel also. But this time I am getting error saying I already installed joomla and cant create the database. I cant I installed the previous CMS via cpanel because I think some files are missing. Please help. Thanks
_______________________________________ Website I developed for cash advances Toronto company. |
Need some help
You will introduce some bump steer. It all depends on what you do with the suspension. Lowering the control arm mounting points may help. Move it temproary and run the suspension thru its range and see what you get.
Need some help
im actually going to get some Ksport Kontrol coilovers thats why im asking. but thanks man. oh and try and get ranchos next time the monroes are good but ranchos are better
| All times are GMT -5. The time now is 02:30 AM. |
