I have a question I want to improve my suspension I know lowering springs is a good start I just dont want to deal with scrapes and broken body kits puncured ac condensors ect. High speed stabilization is the goal here any suggestions would be appreciated thanks |
OK quick lesson time on springs.
a short spring is stiffer than 1 that is the same guage (thickness) and longer Sooo if you cut 1-3 coils out of your springs they will be stiffer. at a cost of height here is what i did with my 88 2 door legend 5 inch drop on the front 6 inch drop in the back. That left me with a smashed oil pan and a pinched off exaust but man it looked cool 2.5 inches off ground clearence and it couldn't be alighned. Then i built a spring ride height adjuster onto my shocks that allow me to (with the use of shims) raise my car back to stock height in 1/4 inch increments. At stock height i noticed a massive difference in the way the car handled (shorter springs are stiffer) added 5mph on my intown corners and 10mph to my off/on ram speeds... Final results after much messing was; LF spring lowered 2.75 inches RF spring lowered 3.00 inches LR spring lowered 3.50 inches RR spring lowered 3.75 inches left side is higher by a 1/4 inch so when im in it it sits level. that left me with a alighnable vehicle that looks good and with the stiff springs man it handles nice...i still stop for speed bumps and them big ass dips but at least i dont leave parts behind. |
Make sure you get quality shocks for whatever springset you decide to use, and ask the seller if the shocks will handle the springrate, etc/. Dont cut your springs man.Edited by: GS-Teg00
I agree, spring cutting is a bad idea. I'd go with a 1.5" drop, it gives the control and gives a nice look. You need a camber kit obviously and an alignment or you can kiss your tires goodbye. I'm having trouble with my camber being out of alignment after I used had it professionally aligned yesterday. |
Don't cut your springs. I had a bad time with that. My old vehicle was a 97 Ford Ranger and I dropped the back and the front. Cut half the coils off the springs. Yeah, it sat low, but the camber on the front tires was horrible. Needless to say, I was in the shop replacing my springs in a week to stock height.
| All times are GMT -5. The time now is 01:08 AM. |
