| your_xtc |
Jul 31, 2006 11:13 AM |
A lot of this is useless info. First your cars don't sacrifice anything on gas to use a heater. Not enough to notice anyway. A/C yes but if you drive with the windows down then you have the drag issue. Best solution. Racing pulley. Doesn't increase horsepower but preserves it when you run things like A/C. This will help with some of your gas mileage but not all of it. But you will also notice the increase in hp when running your ac. Maint on your car and how you drive it is what you need to worry about the most. Remember the higher the RPMs on your car the more gas you burn not much else will be that noticeable on your car e.g (how you stop or wether you leave your car running or not while you are in the store) good way to get your car stolen. Drive like a sane person and save on gas drive like a bat out of hell. Spend more on gas.
