I have a 98 RL 3.5 My keyless entry opens the doors fine but doesn't work for the trunk...any ideas? Edited by: 98GLToronto |
Hell New Member: Thank You for joining up with us..some one will have an answer for you here in the forum, so just be patient... WheelBrokerAng [img]smileys/smiley14.gif[/img] |
hmmm.
does the trunk open with the button in the car or do you have to use the key? the keyfob could also be damaged and may need replaced i have also seen a weak batt in the fob just have enough power for 1 thing but not the other. hop on 1 foot rub your tummy while huming the toon to dixy land. oh wait thats a code read never mind. |
The trunk does open from the driver door button...I'll try changing the batt and see if that helps...
If I remember correctly, you have to hold the remote button down more than 1 second to activate the trunk release. If your remote battery is weak it may not provide enough juice to send a signal for more than a second.
| All times are GMT -5. The time now is 04:09 AM. |
