RL 2005 radio code
i thought you can get the radio code with a bin #
dealer wants serial # of the radio to give me the code any pcitures of removing the radio, its nav by the way |
Radio Code
I bought my 2005 used and I found the radio code on the yellow 100& something point inspection they gave me. Mine was 45543 and Nav was 1734 I doubt if ether one will work on yours. The dealers want to charge you $50 to put it in for you and it it takes them 30 seconds to do it, but they want you to leave the car for 1 hour. Look in every book and paper you got from when you bought the car. I had a 1980 legend that I found the code under the spare tire. Good luck........
After disconnecting my battery I also had the radio lock up. Best solution I could find online was this service I used:
Acura Radio Code - Radio Locked? We'll Unlock It! |
After disconnecting my battery I also had the radio lock up. Best solution to get a radio code I could find online was this service I used:
| All times are GMT -5. The time now is 01:57 AM. |
