-   RL (https://www.acuraforums.com/forum/rl-15/)
-   -   1999 Acura RL Headlight issue (https://www.acuraforums.com/forum/rl-15/1999-acura-rl-headlight-issue-6615/)
kzookid Apr 21, 2013 09:14 PM
Hello,
I still love my Acura which I purchased with 39k miles on it and I am now rolling with 260k
My goal is to take it to 300k which will give me another 2.5 years but I need some help/advice. My question:
I have a headlight that works itermittently. The last time I purchased those headlights, I was told they last approximately 7 years. When I see that the light is out, I can turn the lights off and on and then it comes back on. Sometimes it stays on for the rest of the trip or sometimes I have to turn the lights on and off several times to get the light working. Anybody had that issue? Could there be another issue that is causing the intermittent behavior?
WilsonHenry Jun 5, 2013 10:20 AM
Originally Posted by kzookid (Post 15216)
Hello,
hid xenon kits, I was told they last approximately 7 years. When I see that the light is out, I can turn the lights off and on and then it comes back on. Sometimes it stays on for the rest of the trip or sometimes I have to turn the lights on and off several times to get the light working. Anybody had that issue? Could there be another issue that is causing the intermittent behavior?
Never heard of such problem. Could be huge wiring problem but surely you need expert help to solve it...
WheelBrokerAng Jun 12, 2013 02:02 AM
Check your ground wire that grounds out that headlight to see if there is corriosion at the ground wire itself.
WheelBrokerAng :)
Anonymous58 Jun 24, 2013 10:56 AM
If you need a professional to help solve your problem, you could head to Precision Inc. in Tucson Arizona. They specialize in Honda and Acura repair. If you want more information, here is their website where you can schedule appointments: http://www.tucsonprecisionservice.com
kzookid Jul 24, 2013 01:22 PM
Headlight Issue
Big Thanks to WilsonHenry and WheelBrokerAng for responding to my question. WBAng, I asked the service tech to take a look and what they found was a connection that wasn't tight so they thought they had it fixed. It started doing it again so it might be a bigger deal as they thought they fixed it.
Thanks for the suggestion though. Much cheaper than one of those expensive lights......
poorman212 Jul 27, 2013 11:42 AM
When it goes out....any chance you could check for voltage and ground on the wires to the light?
I know they said the light will last 7 years but they could be wrong. A filiment could be bad causing intermit issues
